Thread: pvc in a crawl space?
03-22-2010, 09:08 AM #1
On a fixer house I am buying (on a well) there is pvc pipe from the well, then under the house to the pressure tank. After the tank it turns to copper for the remainder of the supply.
I want to abandon the well and connect to city water.
I know I can use the existing pvc line from the well to the house. But can I keep the existing pvc line that is under the house? Eliminating the pressure tank and tie it into the copper system.
I looked at an old upc book and it stated the pvc is not allowed under a structure.
Have the codes changed to allow pvc under a structure?
Why would you not be allowed to use pvc under a structure (in the crawl space)?
I understand that cpvc is allowed under a structure why not pvc?
03-22-2010, 01:12 PM #2
Re: pvc in a crawl space?
03-22-2010, 06:28 PM #3
Not even supposed to use the PVC under the structure for the service line from the well.
Nope, the code still do not allow PVC under a structure when used for pressure uses.I looked at an old upc book and it stated the pvc is not allowed under a structure.
03-26-2010, 08:28 AM #4
2006 IRC Table P2904.4 allows PVC pipe meeting ASTM D 1785; 2241; 2672; or CSA B137.3 standards to be used for water service pipe. ASTM D 2241 and the CSA standard are for pressure rated pipe. CPVC is also allowed as water service pipe. More likely that the pipe is polyethylene or polypropylene though.
03-26-2010, 04:30 PM #5
Re: PVC in a crawl space?
