Thread: Hot & Cold
    Scott Murdock's Avatar
    Scott Murdock Guest
    Default Hot & Cold
    Ok, We all know that hot is on the left and cold on the right. What if the control goes forward and backward. Should hot be toward you or away from you as you pull or push the control forward and back?
    Default Re: Hot & Cold
    I don't think that's defined in the code..... so it just has to match the labeling on the faucet.
    Scott Murdock Guest
    There is nothing on the faucet. I couldn't find anything in the code books.
    That is what is defined in the code.
    Quote Originally Posted by Scott Murdock View Post
    There should be something on there to indicate where hot is and where cold is, albeit not always clearly labeled.
    Scott Murdock Guest
    I could not find anything. No blue dot or "C". So it must be OK the way it is. Maybe the marking wore off?
    Thank you for the input.
    If you lay that faucet down it would resemble a kitchen faucet and as it is shown in the picture backwards would be hot. Hot being on left if it were laying down. Honestly though I think just about anyone is going to get twisted up with that faucet at first until they use it the first time and wait for the water to com out. As Jerry said there should be something somewhere on that fauscet to indicate hot and cold or there should have been and the installer did not install it. It could have been a colored ring with the red on the left and blue on right. Being that it is what it is now you should have just noted which direction the hot was in in your report and verbally explained to the client.
    Teresa Testarosa's Avatar
    Teresa Testarosa Guest
    Thanks for the information...
    chris mcintyre's Avatar
    chris mcintyre Guest
    I think that forward should be the cold, because a small child would almost certainly pull the handle forward to turn on the water.
