Results 1 to 12 of 12
    Sep 2009
    Twin Cities, Minnesota
    Default water heater inspection
    I was inspecting a gas water heater (Richmond, 2003). I turned the temp up a little (not all the way) so I could see the burner fire and see inside the burner chamber. I left the temp up for a few minutes b/c I wanted to listen for anything knocking. After a few minutes water started leaking out the discharge pipe connected to the TPR valve. I opened the hot water at the laundry tub to relieve the pressure and turned the temp on the water heater back down and it stopped leaking. Is this typical or does this mean there's a problem with the TPR valve?
    -Jon
    Errickson Home Inspections, LLC
    http://www.erricksonhomeinspections.com
    Sep 2008
    Texas
    Default Re: water heater inspection
    If the TPR valve has been tested quite a few times it could have some trash in it or the spring could be weak.
    I would recommend having an experienced/qualified plumber to replace the valve.
    mike huntzinger's Avatar
    mike huntzinger Guest
    sand can get under the rubber seat , try blasting water through the TPR a few times
    Tony Watson's Avatar
    Tony Watson Guest
    Sounds like the TPR valve is acting as the thremal-expansion device.
    Ron Bibler's Avatar
    Ron Bibler Guest
    Sounds like it done... Call for a plumber...
    I don't mess with things like that. If they start some kind of a problem?
    Ouch...
    Best
    Ron
    Feb 2010
    Omaha
    Hard water build up stops them from reseating. I would never open a TPR that I didint intend on replacing.
    Sep 2009
    just to clarify -- I didn't open the TPR valve. I just turned the temp up at the dial so I could get a look at the flame and burner chamber. After the temp was up for a few minutes, that's when it started leaking.
    How do other people inspect water heaters?
    -Jon
    Quote Originally Posted by Jon Errickson View Post
    Wash my hands
    Sounds like a worn/faulty TPR valve - it's a $10 fix.
    I turn them up sometimes if I'm suspect of some other problem and want to watch it run. Usually, gas ones kick on at some point while I'm doing something else and I can watch/hear it go through a cycle.
    Feb 2010
    Omaha
    Soundslike the TPR was doing its job -released excess pressure. You turned it up and increased the pressure which trip the relief. When operating at a lower temp this has not been a problem. If they were to run it at a higher temp then they may need an expansion tank.
    I would let the homeowner know it tripped and tell them to keep an eye on it.
    Sep 2009
    I think in the future I may not turn the temp up, but just run the hot water for a bit until the water heater kicks on. Thanks for all the responses.
    For my own info: if you're replacing the TPR valve do you have to drain the tank or just run the TPR until no more water comes out? Then just switch it for another, right?
    -Jon
    "I think in the future I may not turn the temp up, but just run the hot water for a bit until the water heater kicks on."
    That sounds like a good idea.
    "For my own info: if you're replacing the TPR valve do you have to drain the tank or just run the TPR until no more water comes out? Then just switch it for another, right?"
    Thats about it.
    Oh, sometimes the drain will break or continue to leak also.
    However, it sounds to me as though the TPR NEEDED replacing.
    Learn how to say "Failed under test".
    New Mexico
    Any chance it was a boiler RV, instead of a WH TPR? They will release at 30 PSI. I don't normally read the fine print, although it's probably a good idea. They look very similar to people, and if they put in the WH themselves, I could see that happening. Most come with a TPR valve already, but I don't know if they all do.
