Results 1 to 21 of 21
Thread: Trap 2-fer
04-23-2010, 07:41 PM #1
Trap 2-fer
Found a 2-fer today. Two P traps sharing a single vent under the kitchen sink AND an S trap in the master bath.
I guess you could call it a 3-fer since the dishwasher did not have a high loop before it emptied into the garbage disposal using the shared vent between the 2 P traps.
Similar Threads:Last edited by Bruce Ramsey; 04-23-2010 at 07:46 PM. Reason: add pics
04-24-2010, 05:46 PM #2
Re: Trap 2-fer
I do not see a problem having two traps.
04-25-2010, 04:42 AM #3
Re: Trap 2-fer
The trap in the third picture in the bath looks okay too. They used a P trap and PVC 90^. How else could it be done?
04-25-2010, 05:04 AM #4
Re: Trap 2-fer
With an aav so that it's vented.
04-25-2010, 06:41 AM #5
Re: Trap 2-fer
Good point....
04-25-2010, 07:20 PM #6
04-25-2010, 07:22 PM #7
Re: Trap 2-fer
There are two trap arms shown, one from the vent out to the right and one from the vent out to the left, that is allowed.
The third photo is an 'S' trap and is not allowed, the easy correction is an AAV as John said (and James added as a "Good Point").
04-25-2010, 09:56 PM #8
Re: Trap 2-fer
Disposal should have a air-gap device or high loop
04-26-2010, 12:06 AM #9
04-26-2010, 03:02 AM #10
04-26-2010, 03:59 AM #11
Re: Trap 2-fer
04-26-2010, 04:34 AM #12
Re: Trap 2-fer
In the third picture I was thinking the vent was not visible...like it was vented like an island sink would be.
04-26-2010, 04:53 AM #13
Re: Trap 2-fer
In the third picture I was thinking the vent was not visible...like it was vented like an island sink would be."
An island sink, like this one, should have a loop vent, however, in most areas an AAV is allowed.
04-26-2010, 06:44 AM #14
Re: Trap 2-fer
I have seen wet venting allowed on island sinks but if the pipe is not sized properly it can siphon the trap.
04-26-2010, 06:50 AM #15
Re: Trap 2-fer
04-26-2010, 09:05 AM #16
Re: Trap 2-fer
Maybe I was not very clear in my wording.
I should have said:
An island sink, as well as this one, should have a loop vent,...
04-26-2010, 07:30 PM #17
Re: Trap 2-fer
04-26-2010, 08:26 PM #18
Re: Trap 2-fer
Have it fixed by someone who not only understands drainage, but also venting.
Ya just gotta wonder sometimes.
05-26-2010, 08:02 PM #19
Re: Trap 2-fer
100 yr old house coverted into apartment building. "Plumber" used the same technique in all 4 kitchens.
Two bowl kitchen sink. Individual traps on each bowl T'ed into a single pipe that goes down and and out but no vent. Do these become doubled S traps?
Since the two traps share a pipe before they exit and there is no visible vent, then this is not a valid configuration?
05-26-2010, 08:07 PM #20
05-27-2010, 01:58 AM #21
Re: Trap 2-fer
Bruce
Pics 1,2,&3, are S Traps. Pic 4, I cannot tell, it looks like ot goes into the wall, so it could be vented.
