Results 1 to 9 of 9
Thread: SEEP WELL
05-27-2010, 06:11 AM #1
05-27-2010, 07:25 AM #2
Re: SEEP WELL
Why is the water "seeping" uphill?
05-27-2010, 08:41 AM #3
Re: SEEP WELL
sounds like an artesian spring? drilled a well on one jobsite and had good water pressure to run hoses and sprinklers without setting a pump. owner was thrilled!
05-27-2010, 08:47 AM #4
Re: SEEP WELL
This is kind of like that except this well is collecting water from underground seepage, and using it for the house water supply. The kicker is that directly uphill from this well is kerosene tank that has been leaking oil in to the ground for some time.
05-31-2010, 09:45 AM #5
Re: SEEP WELL
BrianSchmitt got it.
Booster/collection well for a spring fed or SEEP water source. Be it surface, ledge, or subterrian cavern.
05-31-2010, 10:57 AM #6
05-31-2010, 11:22 AM #7
Re: SEEP WELL
That's not how I read it (the Original Post), regardless what I said was correct regards what a seep well (spring source well) is. Read again, highlighting, color and underline added:
As I read it, a PUMP exists at the seep well collection (according to the seller's claims).
05-31-2010, 05:30 PM #8
Re: SEEP WELL
A backup pump exists which pumps water out of the trinity River when the seep well runs dry, which it does, according to the seller.
05-31-2010, 05:33 PM #9
