Results 1 to 11 of 11
    Shane Dredge's Avatar
    Shane Dredge Guest
    Default Dishwasher directly into a trap in the crawlspace
    Can someone give me a hand with the verbiage on this one. This dishwasher drain hose runs through the sub floor and into the crawlspace. No air gap at sink. It then discharges directly into a waste trap. Has anyone ever seen this set up before and what would your statement be in the report?? Any input is greatly appreciated. Thanks
    James Duffin's Avatar
    James Duffin Guest
    Default Re: Dishwasher directly into a trap in the crawlspace
    Here is what the NC plumbing code says -
    802.1.6 Domestic dishwashing machines.
    Domestic dishwashing machines shall discharge indirectly through an
    air gap or air break into a standpipe or waste receptor in
    accordance with Section 802.2, or discharge into a
    wye-branch fitting on the tailpiece of the kitchen sink or the
    dishwasher connection of a food waste grinder. The waste
    line of a domestic dishwashing machine discharging into a
    kitchen sink tailpiece or food waste grinder shall connect to
    a deck-mounted air gap or the waste line shall rise and be
    securely fastened to the underside ofthe sink rim or counter.
    Quote Originally Posted by Shane Dredge View Post
    I do not have my code book handy, but I believe traps are in chapter 32 of the IRC and dishwashers are in chapter 27. Might be an older IRC.
    Ron Bibler's Avatar
    Ron Bibler Guest
    Hope this helps...
    See the PDF.
    Best
    Ron
    Attached Files Attached Files
    Aside from everything else, every dishwasher manufacturer's installation instructions I've seen restricts the allowable length of the drain hose - 10 feet is typical - so most such installations I encounter (which usually involve kluging on some sort of drain hose extension) are incorrect even if other requirements are met.
    Atlanta, Georgia
    Make sure they fix the leak in the dryer vent as well.
    Hey... "flocked" pipes were "in" back then.
    For verbiage - how about "improperly terminated to waste line"? Getting into discussion about air gaps and traps may not be very useful to clients since they'll likely have no idea what you're talking about.
    Sometimes simple and concise works better than anything else.
    Phil Brody's Avatar
    Phil Brody Guest
    As a side note,don't most modern dishwashers have an air gap at the washer itself ?
    "As a side note,don't most modern dishwashers have an air gap at the washer itself ?"
    Well, yes and no.
    I don't remember an integral air gap being on the discharge line of a DW.
    However most if not all DW do have an air gap on the supply line.
    Also many DW do have an anti-back flow valve on the discharge line.
    The problems are, you cannot tell if by looking at it if it has a BF or not,
    even the manual may not help.
    Linda Swearingen's Avatar
    Linda Swearingen Guest
    Here in Kentucky we're prohibited from quoting code in home inspections, so I don't happen to know which section requires the air gap (though I know good and well it's in there.) So what I would tell this buyer is "Dishwasher drain is unconventional arrangement which appears to allow possible backup of sewage into the dishwasher. Recommend having a licensed plumber install a proper drain for this appliance." Although it does not have the "umph" that a code quote would, pointing out the problem that following the code sidesteps is often helpful. (And people are REALLY squeamish about sewage. . .)
