		Thread: Sewer lines on exterior wall
	06-11-2010, 01:54 PM #1 Sewer lines on exterior wall Sewer lines on exterior wallIs it proper to run sewer lines on the exterior wall of a house? This was done as part of a laundry addition at an older home.
	06-11-2010, 03:19 PM #2 Re: Sewer lines on exterior wall Re: Sewer lines on exterior wallNope. Not where run exposed.
 Looks like you are above 'the freeze line', which is basically I-10, so those would need to be protected from freezing by insulation, heat tape, or both.
 Besides being protected from physical damage, sunlight, etc.
	06-11-2010, 03:52 PM #3 Re: Sewer lines on exterior wall Re: Sewer lines on exterior wallDoes protection mean building a box around it or painting and insulating it? Thanks.
	06-11-2010, 06:19 PM #4 Re: Sewer lines on exterior wall Re: Sewer lines on exterior wallDon't know about Texas but in these here parts, painting or building a box around it is not considered proper protection.
 Based on your question I will guess these are above grade sewer lines. Above grade or exposed no longer allowed here.
 I'll defer ... AD where are you ... help the newbie out.
	06-11-2010, 10:20 PM #5 Re: Sewer lines on exterior wall
		John Kogel, RHI, BC HI Lic #47455 Re: Sewer lines on exterior wall
	06-15-2010, 06:40 PM #6 Re: Sewer lines on exterior wall Re: Sewer lines on exterior wall
  Reply With Quote Originally Posted by Jerry Peck
