Results 1 to 3 of 3
Thread: Floor Drain Backup
06-18-2010, 05:04 AM #1
Floor Drain Backup
At a home in city limits, if the area around a floor drain is very wet indicating a backup, what would you advise?
If its backing up, it is likely from the storm drains correct?
Would you call the city utility?
06-18-2010, 05:24 AM #2
Re: Floor Drain Backup
Floor drains do not connect to storm drains. They are part of the buildings sewer system.
If it has backed up during a heavy rain, it is best to call the city and ask them if their sewers are flowing. If it is not a city sewer issue, then you will need to hire a drain cleaner.
Ron Hasil IL Plumbing Lic #058-160417
A-Archer Sewer & Plumbing specializing in:
Tankless Water Heaters | Drain and Sewer Cleaning | Sump and Ejector Pumps | Backflow RPZ Testing
06-18-2010, 06:29 AM #3
Break out a garden hose on a day it's not raining, and see what happens. If it backs up, then you'll need to get a drain snake in action. Hopefully, it's just a clog and not a larger problem. You probably can't see where it terminates, which would be helpful. Some of them run to a French drain, others to the sewer, and some will drain to daylight.
