Thread: Liquid Propane
    RobertSmith's Avatar
    RobertSmith Guest
    Default Liquid Propane
    I'm being told that combustion air venting for a heater/water heater that uses liquid propane in a closet is not needed ; is this true? if so why?
    Rob
    David Bell's Avatar
    David Bell Guest
    Default Re: Liquid Propane
    Direct vent? Louvered door? Has to get combustion air from somewhere.
    Combustion air needs are the same for natural gas as propane. Someone misunderstood the question or you misunderstood their answer or they are just full of crap.
    Quote Originally Posted by RobertSmith View Post
    Rob
    As Jim and David have said, it has to get air from somewhere! This is when you ask the person that tells you this to provide the document that cites what they are saying.
    Mar 2008
    Charlotte NC
    Aside from the requirement for combustion air, you need to insure the closed closet does not become a confined space. LP gas will pool at the bottom of the closet if there is no vent or drain to let it out. If it fills with gas it is a bomb waiting for a spark!
    Exclamation LPG
    FYI-Liquified petroleum gas
    If it uses combustion, it uses air from somewhere. Make and model?
    Quote Originally Posted by David Bell View Post
    Direct vent?
    I suspect you are referring to adding combustion make up air vents. A direct vent appliance does not need combustion make up air vents as it gets all of its combustion air directly from the outside.
