    Jon mackay's Avatar
    Jon mackay Guest
    Default Toilet drain line size
    Is there a minimum size for a toilet waste line?
    I came across a 3" cast iron line from a toilet and it just didn't look right.
    NHIE Practice Exam
    Default Re: Toilet drain line size
    Why don't you go ahead and access the New York State Residential Codes?
    Apr 2007
    state of jefferson
    3" is the minimum size for A toilet.
    Jon mackay's Avatar
    Jon mackay Guest
    Is there a link to that?
    Jon mackay's Avatar
    Jon mackay Guest
    This was a small commercial office that has a history of the toilet backing up. When I saw the 3" I just thought I would throw it to the forum as all the residential toilet lines I find are 4".
    Nov 2007
    Chicago
    THe Picture is from the New York State Code. Look at the foot note (a.) it states the minimum size of any buidling drain serving a water closet shall be 3" Here is a link to the state plumbing code 2006 New York State Plumbing Code
