Results 1 to 10 of 10
    Default ABS to PVC connection
    I'm sure this has been posted before but I didn't find it quickly so here goes... I inspected a 1974 home yesterday and a portion of the sewer line was ABS and PVC. I don't know of a solvent that would allow this connection to work?? Although, it all seemed to be working just fine. We filled every fixture and let them go. There were no signs of previous leaking at ceilings or walls that would indicate a problem either. My question is... Have I been misinformed about the two of these product being compatible?
    Thanks,
    Reis
    Mar 2008
    Charlotte NC
    Default Re: ABS to PVC connection
    There are products manufactured that say they can join PVC to ABS, but the last I knew they were not approved. Just who has to approve it I don't know. These cements weren't around in 1974 so it is probably a moot point. I have seen quite a few PVC to ABS joints and none were leaking, but I still write them up as incorrect.
    Atlanta, Georgia
    My understanding is the two materials expand and contract at different rates. Places where they are glued together are more likely to fail since they move at different rates.
    The glues for both products basically melt the product. ABS and PVC are different products and require different materials to melt them. Once melted they have to harden but you have co-mingled the products such that they are neither PVC or ABS but a mixture.
    David Bell's Avatar
    David Bell Guest
    Local codes dictate whether chemically bonded pvc to abs is kosher. There are cements that are NSF standard 61 for DWV and sewer but, these systems can not be tested with compressed air.
    Apr 2008
    Western Massachusetts
    David Bell's Avatar
    David Bell Guest
    Quote Originally Posted by Corn Walker View Post
    Thats one of the cements I was talking about, but look at the spec sheet, it still defers to local codes.
    Succasunna NJ
    Here's The Great State of New Jersey's official position on this subject.
    Attached Files Attached Files
    Art Dotson's Avatar
    Art Dotson Guest
    ABS & PVC are different polymers. The solvent cements used for either will temporarily melt either material. After the solvents evaporate what you have is a sort of mechanical connection rather than the weld that you would have joining like materials. Hence, the restriction to use on non pressure piping systems. No code worth adopting would condone the mixing of different piping materials without the use of a proper connection between the two. I have disapproved many installations of mixed materials with solvent cement joints. Even in DWV systems just some light lateral strain on these joints will often cause them to fail and start leaking.
    Art Dotson
    Construction Code Services, LLC
    Walnut Grove, MO
    jimsonburg's Avatar
    jimsonburg Guest
    Jointing the ABS and PVC while both systems of pipe jointing primarily rely on a cement system, ABS and PVC have different molecular structures and different thermal expansion rates. The pipe make-ups and materials are different and so too are the cements, which are of different solution and manufacture and are not cross compatible, according to the solvent manufactures.
    Mar 2010
    conyers, ga
    Geez Edith, Now they're regulating blow up pools
