Results 1 to 13 of 13
09-21-2010, 09:59 PM #1
What was this device doing in the crawlspace?
What was this device doing in the crawlspace of a townhouse? Does it look like it is installed correctly?
Similar Threads:John Kogel, RHI, BC HI Lic #47455
09-21-2010, 11:03 PM #2
Re: What was this device doing in the crawlspace?
Water meter with remote sensor (the wire lead)
I would think support for the meter itself would be required but I've never seen that before. We put meters here in a box underground.
09-22-2010, 06:09 AM #3
It's fine, except they didn't install shut offs at either end to allow the water company to change or service the unit.
09-22-2010, 06:10 AM #4
Never seen a water meter installed like that or in that type of location. Seems very funky. You'd probably have to contact the water department for info on their requirements for placement.
09-22-2010, 07:15 AM #5
The management company could be doing their own metering and charging for the water used. Just a guess. Is the development on a community water system?
09-22-2010, 08:27 AM #6
looks like poly tubing down there, i'm sure you wrote that up.
09-22-2010, 08:27 AM #7
09-22-2010, 08:30 AM #8
09-22-2010, 05:25 PM #9
Possibly a sub-meter to meter water usage for hose bibs which would be charged for water only. Many jurisdictions allow use of sub-meters so owners don't pay for sewer charges for outdoor water use. Would need to determine where the line goes downstream of meter.
09-22-2010, 08:10 PM #10
Sub-meter?? Let's see Jerry find an avatar for that!
09-22-2010, 08:27 PM #11
sorry john
but from the picture the tubing looks like the gray deadly color of POLY, and crawl spaces is where you find.
how old is the house /
cvf
09-22-2010, 09:38 PM #12
Jon, I've added "submeter" to my vocabulary anyway. Submarines use water, too, don't they?
No harm done Charlie, I know you meant well.
It's a 2004 house. PEX has become the pipe of choice where I live. All you need is a package of rings and the tool can be rented for a few bucks.
09-22-2010, 11:39 PM #13
It looks like gas line connecting with a meter from main line to home line. But, I have not seen meter fixed there because most of the meters are fixing at out side of the line not under the home line.
