Results 1 to 9 of 9
Thread: Gray PVC
    New Mexico
    Default Gray PVC
    I don't think I have seen this before. It is actually labeled PVC, with an ASTM D2665, just like the white PVC it is connected to. Was this a product that was in use a while ago? This addition was pretty old. I think it was put up in 1976-1978.
    Inspection Referral SOC
    David Bell's Avatar
    David Bell Guest
    Default Re: Gray PVC
    Most of the grey pvc I have seen is schedule 80. It has a higher UV rating and can handle higher tempuratures.
    That is a commercial grade or quality PVC that you will see mostly in commercial buildings. It is still in use today.
    New Mexico
    Thanks. They must have been cleaning out the truck. They had white PVC, gray PVC and ABS all patched in on the drain lines. I couldn't read if it was schedule 80 or not, but that would make sense.
    Mahtomedi, Minnesota
    Love the tape!
    What holds the joints together?
    Fred Comb, ACI
    Mahtomedi, MN
    www.homeinspectionsofmn.com
    New Mexico
    The tape was on the insulation around the supply lines for the bath..
    Succasunna NJ
    Is that a leak bottom left?
    Mesa, Arizona
    Wood top right looks wet also.
    Jeff Moore AZ Cert#49250
    Level II Thermographer
    http:www.quantumhomeinspections.com
    The colors have no real meaning industry wide, some gray PVC may be schedule 80 but the ASTM posted is schedule 40. Some early versions of PVC were colored "industrial gray" not to be confused with actual industrial grade.
    www.BAKingHomeInspections.com
