Thread: Gas Piping Connection
11-10-2010, 07:14 PM #1
I am concerned about this connection. It appears that there is some condensation on the connection which could be from a leak. Any opinions?
Jim Murphy
11-10-2010, 08:57 PM #2
Re: Gas Piping Connection
Do you think it could be leaking gas from all three connections? It may be residue and corrosion due to the flux used in the soldering process. Are there any pics of other gas pipe connections?
11-12-2010, 09:19 AM #3
NFPA 54 states that nonferrous gas pipe connections can only be brazed with a material that has a melting point in excess of 1000 degrees F. If these are soldered joints they would not be acceptable. Also if the gas contains certain amounts of hyrdogen sulfide, copper pipe is not alowed. I assume this is because it could cause a reaction with the pipe or sealing compounds which might be what your seeing. I would check with the local gas supplier for their opinion.
Galen L. Beasley
Inspections Supervisor
Housing Authority of Kansas City MO
12-09-2010, 10:41 AM #4
Galen, you make several excellent points - thank you Sir!
I have seen something like this in the past and now I will add some of your language to my reports for when I see it again.
I never considered checking for the presence of simple soldered connections on copper gas lines.
Just another reason to like black pipe over the softer/flexible stuff...
David Moore
12-10-2010, 01:41 PM #5
Such sweet Joints, too! Obviously a professional job.
12-10-2010, 05:36 PM #6
12-15-2010, 02:13 PM #7
besides that pipe was not cleaned after soldering (left over paste will corrode pipe), its also not secured properly.
12-24-2010, 01:20 PM #8
Judging by the blackening and stippling of the tubing, (signs of excess heat) I'd say these are brazed joints -- Soldering at temperatures high enough to cause that kind of blackening and stippling would have burned out the flux and the solder wouldn't have stuck to the tubing, let alone flowed into the fitting.
Poor craftsmanship -- A person interested in craftsmanship would have wiped and burnished the tee and the tubing and supported it better than is presented.
