    Knoxville, TN
    Default Two air check valves?
    Any idea why someone would put to air check vents under a kitchen sink?
    Default Re: Two air check valves?
    Maybe it's DIY and the homeowner originally had one valve and thought it was noisy or not venting well enough so he's trying two? Just speculating. Sounds like something I'd do.
    I'll bet the trap was clogged with bacon fat and the first air valve didn't fix it.
    Mar 2008
    Charlotte NC
    It's a double bowl sink!
    "Any idea why someone would put to air check vents under a kitchen sink?"
    Because there's not enough room for 3.
    Dang. Why couldn't I have thought of that?
    Nov 2007
    Chicago
    Here is a good link to see if your state approves a mechanical vent. STUDOR (R) inVENTive Technology (TM) - Air Admittance Valves
