Results 1 to 3 of 3
    Jeff Eastman's Avatar
    Jeff Eastman Guest
    Default WH draft hood, insulation clearance
    Default Re: WH draft hood, insulation clearance
    Is the vent pipe single wall or b-vent? If single wall, then you don't have to worry about the draft hood - you have to have 6 inches from the vent pipe that connects to the draft hood.
