Results 1 to 3 of 3
07-25-2007, 10:27 AM #1
WH draft hood, insulation clearance
Similar Threads:Last edited by Jeff Eastman; 12-20-2007 at 08:07 AM.
07-25-2007, 10:40 AM #2
Re: WH draft hood, insulation clearance
Is the vent pipe single wall or b-vent? If single wall, then you don't have to worry about the draft hood - you have to have 6 inches from the vent pipe that connects to the draft hood.
07-25-2007, 12:48 PM #3
