Thread: AAV
    mathew stouffer's Avatar
    mathew stouffer Guest
    Default AAV
    Can this vent be replaced with an AAV?
    Default Re: AAV
    "Can this vent be replaced with an AAV?"
    Yes
    But why would you?
    Default Re: AAV
    People are crazy, wanted extra storage, didn't like the way it looked
    Utah
    Default Re: AAV
    Isn't this just a typical island vent?
    Widdershins Saunders's Avatar
    Widdershins Saunders Guest
    Default Re: AAV
    The upper portion was done incorrectly, which means the lower portion was done incorrectly as well -- So they'd probably be better off if they did eliminate it.
    Apr 2007
    state of jefferson
    Default Re: AAV
    Quote Originally Posted by Widdershins Saunders View Post
    would you like to elaborate a little?
    Default Re: AAV
    There should be a 2" cleanout located under the 2"x1-1/2"x1-1/2" Sanitary Tee and since this is below the flood rim, the upper radius should be constructed out of drainage fittings -- A medium sweep 90 in this orientation is not considered a drainage fitting.
    If they screwed the pooch on those two things, then they likely screwed the pooch on the drain and foot vent below the floor.
    Apr 2007
    state of jefferson
    Default Re: AAV
    w,
    good call on the cleanout, but no requirement for drainage fittings on the vent portion in the u.p.c. anyways. i rarely see these done right by diyers.
    the code says a 45, 90(1.6 rad), 45 . it specifies drainage fittings for all parts of the vent below the floor only!
