Thread: AAV
02-04-2011, 06:57 AM #1
02-04-2011, 07:12 AM #2
Re: AAV
"Can this vent be replaced with an AAV?"
Yes
But why would you?
02-04-2011, 07:39 AM #3
Re: AAV
People are crazy, wanted extra storage, didn't like the way it looked
02-04-2011, 10:07 AM #4
02-07-2011, 06:57 AM #5
02-07-2011, 11:05 AM #6
02-07-2011, 01:28 PM #7
Re: AAV
There should be a 2" cleanout located under the 2"x1-1/2"x1-1/2" Sanitary Tee and since this is below the flood rim, the upper radius should be constructed out of drainage fittings -- A medium sweep 90 in this orientation is not considered a drainage fitting.
If they screwed the pooch on those two things, then they likely screwed the pooch on the drain and foot vent below the floor.
02-07-2011, 04:54 PM #8
Re: AAV
w,
good call on the cleanout, but no requirement for drainage fittings on the vent portion in the u.p.c. anyways. i rarely see these done right by diyers.
the code says a 45, 90(1.6 rad), 45 . it specifies drainage fittings for all parts of the vent below the floor only!
