Results 1 to 16 of 16
    Edward Rodriguez's Avatar
    Edward Rodriguez Guest
    Unhappy Water heater gas shut-off?
    Is there a TP valve/Gas shut-off combination? Is it substandard? Correct me if I am wrong, but a shut-off valve, cap or plug should not be connected at the TP valve discharge. I've never run into this, can someone help me out? I would really appreciate it. The attached picture shows the fuel supply lines running in and out of what appears to be a TP valve/gas shut-off combination.
    Default Re: Water heater gas shut-off?
    Quote Originally Posted by Edward Rodriguez View Post
    I'm totally lost.... you're mixing gas and water in the same pipes with your question?
    From the picture things look pretty screwy but we need some clarification and/or more info to help you.
    There is a valve that is designed to shut off the gas when overtemp/pressure is detected but your photo is not clear enough to tell much about it. Have a photo from further back to show where the lines go and a close-up of the valve?
    Suggest you look at the Watts site to see what is available. LF210-5 Lead Free* Automatic Gas Shutoff Valves , Automatic Gas Shutoff Valve, Water Safety & Flow Control - Watts
    Edward
    As Jim pointed out, what it looks like you have is an automatic gas shutoff.
    When the temperature gets to high the valve shuts off the gas, thereby keeping the temperature from rising any more.
    What I don't see in the photo or on the Watts site, is a pressure relief valve.
    The valve may be able to handle an over-temperature condition, but it is not able to handle an over-pressure condition.
    A separate pressure valve will be needed for that.
    Both temperature and pressure are required.
    Mike Inspector's Avatar
    Mike Inspector Guest
    Watts 210 valve
    Mike
    Thanks fellas for all your help.
    Russel Ray's Avatar
    Russel Ray Guest
    If you read through the Watts 210 installation instructions, you'll find that you still need a TPR valve and drain pipe. Plumbers here never install it until I note its absense and provide a copy of the Watts 210 installation instructions.
    Widdershins Saunders's Avatar
    Widdershins Saunders Guest
    Quote Originally Posted by Russel Ray View Post
    The Installation instructions call for a Pressure Relief Valve, not a Temperature Pressure Relief valve, Russ.
    Mar 2008
    Charlotte NC
    Edward;
    Does your local AHJ allow galvanized gas pipe? Doesn't seam like a good idea to me.
    Bill Brooks's Avatar
    Bill Brooks Guest
    Wow if you look close you will also notice they used standard t tape on the treads which is a no no. You can only use approved t tape which is yellow or approved pipe dope on gas lines.
    Quote Originally Posted by Bill Brooks View Post
    That is actually a fairly recent requirement -- Last 5 or 6 years or so.
    This installation looks like it predates the requirement.
    Edward;
    Galvanized pipe in gas piping is kind of a West Coast/UPC thing.
    I use it when penetrating masonry (brick fireboxes, foundations, CMU block etc. . . ).
    Steel is less susceptible to corrosion from lime than iron is.
    Another big difference is in how the NG is sourced.
    Most NG on the West Coast and into the Rockies comes from the North Slope in Alaska, which is very dry, while NG supplies in the Midwest and East Coast are often cracked from coal, which can leave a lot of moisture in the finished product.
    Jul 2010
    Washington
    It would be nice to see if this installation has a PRV mounted on top of the unit. It looks like the installation instructions show a condition with the pressure relief valve inline with the hot and gas shutoff at the side tap. (Figure 1.)
    Why would only a PRV be installed when you could have the added safety of a TPR?
    May 2010
    St. George, UT
    Quote Originally Posted by Luc Lamarche View Post
    I wonder if the reasoning behind this is because if you used a TPR (not just a PVR and Watts 210) and it (TPR) opened at a slightly lower temperature than the Watts 210, the 210 would be prevented from doing it's job and shutting off the gas.(?)
    New Mexico
    It allows a PRV to be placed at a different location, so that it can drain by gravity. The Watts 210 is usually used where the water heater is landlocked, or too low to drain by gravity, in my experience, like in a basement area.
    Quote Originally Posted by Larry Morrison View Post
    Exactly right.
    I couldn't have said it better myself.
