Results 1 to 13 of 13
    Apr 2007
    WESTMINSTER CO
    Default PEX PIPE OR CONDUIT
    hey all
    saw this tubing in attic with no markings---looks like pex pipe--but there was not any red for the hot water. is there a wire conduit like this??? and does this look right?? it was also in utility room but only a small portion visable--and it didn't connect to any sinks--water heater
    cvf
    Default Re: PEX PIPE OR CONDUIT
    I'm thinking it is PEX ... not like any electrical blue raceway (smurf tube) that I've seen.
    Orlando, FL
    Do they run water lines in the attic in your neck of the woods?
    Looks like it could be structured cable to me.
    I was wondering the same thing ... and if they do, and if those are water lines, those should be protected from freezing.
    Lets try this again.
    Knoxville, TN
    I've never seen blue wiring like that - interesting.
    Seems like it would be pretty easy to tell the difference between PEX pipes and electrical wiring. I think I would have looked closer at where it goes down into the framing.
    By the way, PEX comes in several colors and does not have to be color coded at all.
    Apr 2007
    WESTMINSTER CO
    HEY ALL
    i'm in colorado and it gets cold--never seen any water piping in attic--so maybe rick has something here. may go back and crawl in that attic for any print on the blue mystery.
    thanks
    cvf
    Charlie
    Was the house wired for; Alarm, Intercom, Speakers, automation, satellite and or cable TV?
    Combinations of these often use structured cables.
    Structured cable is very often that color of blue.
    Structured cable often uses hangers like the ones shown.
    Cable droops between the hangers as shown.
    Apr 2007
    WESTMINSTER CO
    house loaded with speakers--security and cable and the kitchen sink.--guess that explains it. great info--you nailed it and gave us all great info
    thanks
    cvf
    Your welcome
    I'm glad to help, and appreciate the confirmation.
    Jeff Kirkpatrick's Avatar
    Jeff Kirkpatrick Guest
    Pex does not have to be color coded. They may have used blue for both hot and cold water.
    Nov 2010
    Newalla, OK
    If this is cable it should have some type of marking on it indicating what it is. You should be able to leave a indent on it with your thumbnail. If it is pex you won't be able to leave a mark. Pex can freeze solid and not break. Used in my house. Great product.
