Results 1 to 3 of 3
    Jon mackay's Avatar
    Jon mackay Guest
    Default Washer discharge configuration
    Is there any instance where it is acceptable to route a washing machine discharge into a one way flow valve and have it pump up into the main sewer line?
    I am thinking no but wanted to verify with everyone.
    I would think recommending a gray water ejector pump would be the proper solution.
    Inspection Referral SOC
    Default Re: Washer discharge configuration
    2006 IRC P2718.1 Waste connection. The discharge from a clothes washing machine shall be through an air break.
    Ah, the "check valve solution"
    "Here is a quick sketch I tossed together to hopefully illustrate my idea."
    There seems to be no limit to DIY creativity (not even gravity).
