Results 1 to 3 of 3
Thread: Washer discharge configuration
03-02-2011, 06:08 AM #1
Is there any instance where it is acceptable to route a washing machine discharge into a one way flow valve and have it pump up into the main sewer line?
I am thinking no but wanted to verify with everyone.
I would think recommending a gray water ejector pump would be the proper solution.
03-02-2011, 06:26 AM #2
Re: Washer discharge configuration
2006 IRC P2718.1 Waste connection. The discharge from a clothes washing machine shall be through an air break.
03-02-2011, 06:40 AM #3
Ah, the "check valve solution"
"Here is a quick sketch I tossed together to hopefully illustrate my idea."
There seems to be no limit to DIY creativity (not even gravity).
