Results 1 to 3 of 3
    Default combustion air for power vented WH
    New construction today - had a high efficiency gas water heater in a small closet. It power vented through the roof. There was only one vent for combustion air, up above the door.
    There has to be a second vent down by the floor, right? The fact that the WH is power vented has no bearing on this requirement?
    Default Re: combustion air for power vented WH
    Here's a pic
    Ray Norton's Avatar
    Ray Norton Guest
    Right you are. If combustion air is not piped in the high/ low vents are required.
