Results 1 to 9 of 9
Thread: Anode problems?
05-24-2011, 02:38 PM #1
Anode problems?
This morning I did a 1 year checkup on a new house I inspected last June. When I drained the first floor bath sink there was a light coating of brown scum left in the sink. It washed out easily. I thought it was mud, but the homeowner said a neighbor told him (3rd hand info) that there was a problem with the sacrficial anodes in the water heaters but the builder would not do anything unless it was specifically called out. Strangely enough the water heater is in the attic, but this only shows up on sinks and toilets on the main floor. The water heater is a State model ES6 52 DORT, mfg. 2010. I read up on these and the anode is aluminum, not magnesium or stainless steel core as on the higher end State water heaters. So, the question is, have any of you heard of similar problems? Also, have problems with the aluminum anodes been documented anywhere? I have not been able to find anything so far.
Thanks in advance!
05-24-2011, 02:59 PM #2
Re: Anode problems?
Is the water supplied from a well or municipal?
05-24-2011, 03:36 PM #3
Re: Anode problems?
City water, but in an outlying area (Chatham County, for those in my areas of NC)
05-24-2011, 04:03 PM #4
Re: Anode problems?
The man reason to use aluminum anode rods is for areas that have a high sulfur content in the water. The sulfur reacts with the magnesium anode rods which makes magnesium sulfide, which has a very strong rotten egg smell. So the aluminum rods do not react with the sulfur as bad so there is no odor. My mother's house we have to remove the magnesium anode rod and install the aluminum rod to keep the water heater's warranty valid.
Never seen the water have a mud film due to the anode rods. And I can not see it affecting the water closets since they are normally hooked up to the cold water supply.
Ron Hasil IL Plumbing Lic #058-160417
A-Archer Sewer & Plumbing specializing in:
Tankless Water Heaters | Drain and Sewer Cleaning | Sump and Ejector Pumps | Backflow RPZ Testing
05-24-2011, 05:45 PM #5
Re: Anode problems?
05-25-2011, 01:52 PM #6
Re: Anode problems?
The brown scum sounds vaguely like rust (iron oxide) especially if it is reddish brown, although iron reducing bacteria will leave a blacker looking scum, but you have to have iron content in the water for that to be a problem, usually found in private wells.
Is there a black iron nipple in the water supply anywhere?
Odd to be only on certain fixtures...
05-25-2011, 03:05 PM #7
Re: Anode problems?
Just from personal experience. We are near the end of a water system and about once a year we have to call the water co. to come out and open the hydrant out front to release iron build-up (usually immediately after my girlfriend fills her bath with brown water).
Water pours out of the hydrant brown for about an 8 count then clears up.
05-25-2011, 03:37 PM #8
Re: Anode problems?
I think I would run some water out of the water heater drain and see what comes out.
05-26-2011, 12:46 PM #9
Re: Anode problems?
Thanks guys. This is what I eventually decided, too. The house is at the end of the development, with an unfinished street a short distance away. I am suspecting that sediment is collecting in the water heater and shows up on the least used fixtures from time to time. Flushing the water heater periodically, and maybe adding a filtration system, is probably the best answer for the time being.
