Results 1 to 2 of 2
    Iron Mountain, MI
    Default Plumbing Wasteline Fixtures
    Hi:
    Can anybody direct me to a decent on-line source for all the plumbing wasteline fixtures (wyes, tees, sanT's, etc) and how they should be orientated? Maybe something that can be printed out and taken with me to inspections.
    Thanks,
    Joe
    Nov 2007
    Chicago
    Default Re: Plumbing Wasteline Fixtures
    Cast Iron, PVC, ABS, and CPVC pipe and fittings for plumbing and industrial systems Charlotte Pipe has catalogs of their fittings as well as technical manuals.
    As for installation orientation, its best to refer to your plumbing code. There was a post about a Tee fitting, and most posted stating that is not allowed. Here in Illinois that is true with one exception. The exception is the waste pipes for a triple basin sink draining into an indirect drain, also a Tee on its back is allowed for a clean out access.
