Results 1 to 10 of 10
Thread: Dishwasher Drain
06-02-2011, 06:29 PM #1
Dishwasher Drain
Saw this setup for a dishwasher drain today. The copper pipe is coming in from the right is from the dishwasher.
06-02-2011, 08:49 PM #2
Re: Dishwasher Drain
I think you'd call that a 'low loop'. Good variety of materials too. I like the cleanout.
06-02-2011, 09:47 PM #3
Is that going up hill after the trap?
06-03-2011, 01:53 AM #4
Very nice indeed where should I start?
IAPMO states: Installation instruction and local plumbing code will dictate the requirements. Most installation instructions require drain connections to be minimum 20" above the floor level of the dishwasher.
06-03-2011, 01:57 AM #5
06-04-2011, 02:39 AM #6
OK it's silly and wrong but with the exception of being able to clean out the black trap I don't see anything functionally wrong. The uphill run is the smartest thing they did !
06-04-2011, 10:51 AM #7
Sheeet thats loocs likes how wees plombs tings aroond hear
06-04-2011, 04:52 PM #8
Ron Hasil IL Plumbing Lic #058-160417
A-Archer Sewer & Plumbing specializing in:
Tankless Water Heaters | Drain and Sewer Cleaning | Sump and Ejector Pumps | Backflow RPZ Testing
06-04-2011, 05:14 PM #9
Here is a picture of the drain downstream from the first picture. It has a little hump in it about midway.
06-05-2011, 05:00 AM #10
Often, when I see this type of install, it also violates the manufacturer's limitation on the length of the drain line, which is typically 10'.
