Results 1 to 14 of 14
Thread: sump pit in bedroom
06-07-2011, 03:07 PM #1
sump pit in bedroom
Is there any code that prohibits having a sump pit and pump in a bedroom closet? The pit has a cover but it is not completely sealed.
Similar Threads:Galen L. Beasley
Inspections Supervisor
Housing Authority of Kansas City MO
06-07-2011, 04:45 PM #2
Re: sump pit in bedroom
Sump pits and sewage ejectors are required to be air tight, sealed and vented to the outside. Location isn't so great but not prohibited.
09-09-2011, 05:30 AM #3
09-09-2011, 05:37 AM #4
I know the local codes for Northern Illinois and Chicago do not require a sump (dewatering) pump to be sealed and vented. Only time they are sealed and vented is when Radon is an issue.
Ron Hasil IL Plumbing Lic #058-160417
A-Archer Sewer & Plumbing specializing in:
Tankless Water Heaters | Drain and Sewer Cleaning | Sump and Ejector Pumps | Backflow RPZ Testing
09-09-2011, 08:05 PM #5
Here in Northern California, I have one in my bedroom and another in the adjoining closet. The AHJ had no issues with them.
My only complaint is the noise issue. I put mine on a timer.
I'd be very interested to hear of other opinions.
09-10-2011, 06:08 AM #6
Did you check the listing, they may have that on as a 1/2 bath
09-10-2011, 10:59 PM #7
09-11-2011, 08:04 AM #8
09-12-2011, 04:24 AM #9
Originally Posted by bruce audretsch
What happens if the sump is full and overflowing, but the timer is off?
09-12-2011, 05:56 AM #10
I have the same concern as Ken....if it is on a timer, what good is it when the power is off?
09-12-2011, 05:58 AM #11
09-12-2011, 06:34 AM #12
Exactly....!
09-12-2011, 08:00 AM #13
umm...no timer. Battery back-up. Set and forget it.
09-12-2011, 01:24 PM #14
In my situation, a timer works. The "flow" is just a constant trickle of groundwater, it doesn't increase appreciably during normal rains.
If we are having a deluge, I disable the timers, and, I have an emergency generator for power outages.
No worries.
And I get no odor from the water or the pit. The stuff coming through is "springwater fresh".
