Results 1 to 12 of 12
Thread: copper piping corrosion
08-07-2007, 10:34 AM #1
I noted this corrosion on some copper piping in a basement and would like to find out what the possible causes or concerns of this condition are.
Thanks Chip
08-07-2007, 11:32 AM #2
Re: copper piping corrosion
It could be flux in the solder.
Bruce Breedlove
www.avaloninspection.com
08-07-2007, 11:49 AM #3
08-07-2007, 11:53 AM #4
As a newbie inspector I'm still not clear on how best to identify copper pipe corrosion. Do you guys write up any time you see the green oxidation? What are some of the other signs that I should be on the lookout for in addition to what the picture shows. Thanks.
08-07-2007, 12:33 PM #5
Scott,
Green oxidation on copper is the same thing as rust is to iron.
It is evidence of a leak. I always write it up.
08-08-2007, 12:27 PM #6
Is it really evidence that there's a leak or just that there is oxidation that may/can lead to leaking? I would be interested in know how you actually write it up.
08-08-2007, 12:50 PM #7
As I see it all the corrosion (green stuff ) is on the joints and that is the result of a plumber not wiping his joints from the flux. This is not necessarily a leak or a future leak. Try wiping away a small amount next time with a wet rag and the pipe under should be clean.
There could be other issues as the pictures and my eyes are not the best.
08-12-2007, 06:39 PM #8
Copper Pipe Information from PlumbingWorld.com
Generally, the green crud is from not wiping off the acid flux. FYI, a lot of schools teach techs to wipe the pipes down completely with flux to shine them up! No rinse cycle. I guess you could test the crud with litmus paper or wet it and sprinkle a little baking soda on it and look for a reaction but I don't know that is recommended anywhere.
HTH,
Bob
08-13-2007, 06:49 AM #9
Everything on Earth (or universe) wants to be the same temperature, the same pH, and the same level. It's only a matter of time.
08-13-2007, 10:19 AM #10
The "green stuff" is oxidation. In these photos, it appears to be due to poor workmanship. Copper tubing, properly installed, will have wiped joints. Several of these appear to be "cold sweat" joints, sweated with water in the tubing, so the solder cools quickly, and appears dull grey instead of silver (unless lead solder was used, which is another thing). I have found pinhole leaks that have developed in as little as 10 years from failing to wipe off the excess flux from sweating copper tubing and fittings. This can be a real pain, particularly inside finished walls. It is always written up as corrosion. Dampness in the basement or crawl space will accelerate the corrosion, as the moisture does react with the flux.
Randall Aldering GHI BAOM MSM
Housesmithe Inspection
www.housesmithe.com
08-13-2007, 11:36 AM #11
Pinhole Leaks in Copper Pipes - Marc Edwards QA
Another article on the problem.
HTH
Bob
08-13-2007, 02:11 PM #12
My father-in-law has been a plumber for about 40 years and I asked him to make sure I am right such as the others are. It is more than likely poor flux cleaning when they sweated the pipes together. My father-in-law said if a copper piipe is leaking corrosion will not stop the leak usually and water drips will be present. I think like the others, its poor workmanship on the plumbers part. You will find a lot of that going around. lol.
