Results 1 to 3 of 3
    Feb 2011
    Ohio
    Default Newer HWT - Above garage floor
    Do the newer types of gas HWTs with the "sealed burners",
    still need to be >18" off the floor of a garage? See photo.
    Thanks in advance.
    Default Re: Newer HWT - Above garage floor
    Quote Originally Posted by Rich Sumen View Post
    Thanks in advance.
    In most areas, the FVIR WH are not required to be elevated.
    You do see that there are other problems that should be reported.
    Feb 2011
    Ohio
    Yes, The rubber extension tub on the TPR extension and where it is directed.
