Thread: Supply Piping Material
09-21-2011, 01:05 PM #1
Hi:
This old farmhouse, built in 1930's has, in part, steel or iron supply piping (I don't know which). I've never seen this material used before. I have seen it used for gas piping.
IRC says ductile iron pipe is ok. Is this material ductile iron?
Thanks,
Joe
09-21-2011, 01:06 PM #2
Re: Supply Piping Material
Here's the photo.
09-21-2011, 01:09 PM #3
galvinized pipe is what you have there and is allowed for water piping.
Ron Hasil IL Plumbing Lic #058-160417
A-Archer Sewer & Plumbing specializing in:
Tankless Water Heaters | Drain and Sewer Cleaning | Sump and Ejector Pumps | Backflow RPZ Testing
09-21-2011, 09:09 PM #4
Joe,
Like Ron said, galvanized steel piping is ok. However, in my area, it will corrode from the inside and close-in, restricting water flow. I operate multiple fixtures in the interior simultaneously and look for a significant water flow drop. Some drop is expected, but when the piping is corroded, it will typically become evident as one or more fixtures will drop to a trickle.
