Thread: Help with this pictures PLS
11-04-2011, 03:16 PM #1
Anyone want to take a shot at this pictures ? What are we looking at ?
Thanks Cory
11-04-2011, 04:01 PM #2
Re: Help with this pictures PLS
What are we guessing at? The split cast iron pipe?
11-04-2011, 04:12 PM #3
Guess?? we are looking at sewer gas eating the top of cast pipe which is typical, that vents at a poor location of an adjoining intersecting roof line
Joseph Ehrhardt
Building Forensic Specialist LLC
11-04-2011, 05:48 PM #4
Some crappy wiring.
#1 Mix of Knob & Tube , Lamp Cord , NMSC, and Low Voltage .
* unknown ( maybe coaxial cable) under split cast iron waste line.
#2 Plumbing Vent before an Addition almost blocked it with abandoned low voltage wire ran thru it.
11-05-2011, 05:15 AM #5
The new intro pictures to This Old Shack?
11-05-2011, 09:27 AM #6
It is a cast iron sewer pipe with a crack in it. It should be replaced.
I'll bet that knob and tube wiring is abandoned but you never know. (Sometimes a voltage sniffer will give a false positive reading if there is active wiring running parallel to the wire.)
The plumbing vent is in a poor location and probably has been since they put the toilet in the house. If there's a flashing there at all, it is leaking.
That wire is somebody's old radio antenna or Grandpa's safety line for sneaking out the window.
The shingle siding is falling off. And there could be several layers on that old roof.
11-05-2011, 03:42 PM #7
Thanks People
By any chance can anyone comment on the possible weld in the cast iron drain ?
11-05-2011, 04:06 PM #8
Read this Cast Iron Welding ( 1st line in Red Sums it up)
