    Clay E White's Avatar
    Clay E White Guest
    Default Water HEater Vent
    Default Re: Water HEater Vent
    Should be properly supported when it changes direction.
    Kalamazoo, MI
    Clearance to combustibles on single walled vent pipes should be 3in and on double walled (B-Vents) should be a min of 1in. Looks like the vent pipe does not meet this.
    Quote Originally Posted by Robert Dalga View Post
    I believe that is 6 inches for single wall vent.
