Thread: Gas pipe saddle valve
01-31-2012, 07:32 PM #1
Came across this today. 1st time ever. Is it allowed? My 1st response would be absolutly not. Your thoughts.
This is tapped into a pipe feeding furnace. Tap goes to an outside grill.
01-31-2012, 07:37 PM #2
Re: Gas pipe saddle valve
Illinos does not allow saddle fittings of any type for gas, water, or drainage.
Ron Hasil IL Plumbing Lic #058-160417
A-Archer Sewer & Plumbing specializing in:
Tankless Water Heaters | Drain and Sewer Cleaning | Sump and Ejector Pumps | Backflow RPZ Testing
01-31-2012, 07:38 PM #3
Those people are lucky there is still a house there to inspect. Unbelievable.
01-31-2012, 08:40 PM #4
I sure would not trust a saddle valve.
That one looks older and not sure what type of gasket is involved.
Certainly would have checked it for leaks.
02-01-2012, 05:14 AM #5
I did check it for leaks, and discussed replacing the pipe that has the saddle valve on it. Thanks for the input.
