Thread: Ball Valve in a Gas line?
02-02-2012, 06:48 AM #1
In California I found a gas line to a barbecue island that has a ball valve. Is a ball valve allowed in a gas line? It seems like it should be water only.
02-02-2012, 07:27 AM #2
Re: Ball Valve in a Gas line?
There are plenty of gas shutoffs that are ball type. Each valve is rated for a specific application. What was stamped on the valve or on the handle?
02-02-2012, 10:47 PM #3
02-03-2012, 08:03 PM #4
WOG does not mean the valve was approved for natural gas or LP (and it's an older pseudo-standard that has since been replaced with CWP and SWP ratings). You need to look for other indicators such as a CSA or older AGA/CGA mark. While valves - ball and gate - with a WOG 600 mark might be suitable for use with gas, unless the valve has a specific mark indicating approval for gas you can't assume it is.
03-20-2012, 03:43 AM #5
The bottom of the gas shut-off valve for a gas meter is to be six inches above final grade level - which your example does not have.
There should also be 36" clear and level in front of the gas meter - which your pic does have.
