Thread: Basement bathtub
02-14-2012, 06:21 AM #1
Basement bathtub
Friend of mine asked if he could install a low profile p trap for his existing basement bathtub. I asked him what led him to think he doesnt have one now. He says he got a look under the tub and its a straight pipe into the slab cutout and into the gravel. Cant see anything beyond that.
questions
1. Is it possible there is a trap down stream, under the gravel, further?
2. what would happen if he did add a trap ahead of one downstream. I think that you cant/shouldnt have two traps
3. If it doesnt have a trap why doesnt the basement smell real bad.
He lives nowhere near me so I cant just walk over and look, and he appears to be camerea challenged, his pics have been useless.
Steve
02-14-2012, 07:22 PM #2
Re: Basement bathtub
Yes, there probably is a trap down there.
... unless the waste line is higher than the tub drain, in which case that may go down to a sump pump which lifts (pumps) the water up to the higher waste line.
02-15-2012, 06:17 AM #3
Thanx Jerry, I am going to suggest he gets a scope and find the trap.
02-15-2012, 06:29 AM #4
How old is the home? and the install of this tub? If there is a trap further down the line it will have to be a drum trap. P-traps have to be directly below the outlet of the tub waste and overflow.
HEre are a couple drawings show what I mean.
Ron Hasil IL Plumbing Lic #058-160417
A-Archer Sewer & Plumbing specializing in:
Tankless Water Heaters | Drain and Sewer Cleaning | Sump and Ejector Pumps | Backflow RPZ Testing
02-15-2012, 08:57 AM #5
02-15-2012, 11:01 AM #6
02-15-2012, 05:48 PM #7
That was my thought too.
Ron, I'm thinking that "down stream, under the gravel, further?" means: down under the gravel a bit further down. Not "down stream in some other location.
I could be wrong, I have been wrong before ... many times.
02-15-2012, 06:13 PM #8
He placed a snake into it and it jammed at about three feet. I put another call to him to remind me how we started this exercise in plumbing.
I am not a plumber and have never heard of a trap burried under the gravel, what a pain in the asp to install...
I have pressed him for photos...
