Thread: AAV
    mathew stouffer's Avatar
    mathew stouffer Guest
    Default AAV
    Can an AAV be installed on an agle.
    Inspection Referral SOC
    Connecticut
    Default Re: AAV
    Cannot be installed at an angle of more than 15 from plumb
    Default Re: AAV
    No, they need to be vertical. Their install instructions or guidelines from the manufacturer tell it all.
    Default Re: AAV
    Thanks. That looks to be about 25 degrees, so it wrong either way
    Default Re: AAV
    The correct answer is:
    And this part of Scott's "Their install instructions or guidelines from the manufacturer tell it all." answer is correct, and the installation instructions will typically state 'to install vertically or not more than 15 degrees from vertical'. Which makes Wayne's answer correct too.
