Results 1 to 11 of 11
    Default water heater glop
    4 year old 40 gallon Bradford White water heater.
    What's with the yellow glop?
    Default Re: water heater glop
    I would think foam insulation used to insulate the tank.
    What would cause it to glorp (technical term) out of the tank like that?
    Chicago IL
    It's a bradford white, it has issues by its very existence. Tell the client to throw it in the alley.
    www.aic-chicago.com
    Whaa?? Bradford White is all we got around here!
    What is wrong with Bradford White's?
    May 2010
    No. San Diego Co., CA
    What does it taste of....?
    tom daley's Avatar
    tom daley Guest
    I cant tell from my view of the pic, but is that fitting a T&P valve? If so, where is the "blow-off" pipe?
    I dont think that that water heater has ever had exterior insulation.
    The injection of the foam insulative sleeve has leaked out when it was injected.
    No big deal, just poor quality control before it was sent out to market.
    Quote Originally Posted by tom daley View Post
    Yes, that's the T&P valve. Yes, missing the discharge pipe. Extremely common finding in these parts.
    Not sure what your point is about exterior insulation, though.
    tom daley's Avatar
    tom daley Guest
    Sorry about that comment ref the insulation. I had another type of insulated W/H in mind, a type that has foam insulation on the exterior skin. Careless of me - due to rushing.
