Results 1 to 11 of 11
Thread: Proper Fitting
    New Mexico
    Default Proper Fitting
    This fitting did not look correct to me. It is directly under the toilet. The line from the left is the drain line from the bathtub. Normally, I see a San T, or something with more of a directional flow. This was more like a cross T. Is this fitting acceptable to tie in the tub drain line to?
    Default Re: Proper Fitting
    Looks to be an okay fitting.
    Typically, you would see the side inlets as a sanitary tee because that is what the code requires for a change from horizontal to vertical, and those side inlets looked to be straight, not curved like a sanitary tee.
    However, after some searching I found this: P418-338 - Spears P418-338 - 3" PVC DWV Sanitary Tee w/ 2" R and L Side Inlets
    This shows a cut-a-way view and the side inlets are curved similar to a sanitary tee, even though the exterior of the side inlets look straight.
    Just Curious Jim,
    What's Connected to the Duct Taped Metal Vent Pipe ?
    Just Curious Jim,
    Billy,
    I figured neither that nor the fitting would matter with all that paper facing exposed on the insulation and ready to burn the place down.
    Billy,
    Good Point,
    At least that way The Fireman wouldn't fall and get hurt from the open sided Stairway.
    Good Point,
    The firefighters would fall because their boots got caught in the open risers with the full height opening ... just the right size for their boots.
    Who needs a guard rail or handrail at that old basement stairs anyway? Silly things just get in the way and look ugly.
    Nope,
    From the looks of the Back Support and Attachment The Stairs would have fell long before The Fire Departments arrival.
    New Mexico
    The metal pipe with the tape is the dryer vent.
    Thanks for the help, all of you.
    Nope,
    That's not the stair support, that's some type of wall. Look closely at the lower left corner of that photo and you will see the stairs are to the left in that photo. The photog was standing near the stairs and facing toward the bottom of the stairs for that photo.
    Mar 2008
    Charlotte NC
    Ten or twelve years ago I had to set for a test to get a permit to run my own sewer line when the septic died. One of the questions was to identify the picture of a "cottage fitting". Never heard of one before, but that is what they called the one pictured by Jim. No I didn't get it right! Been looking for one eversince.
    Nov 2007
    Chicago
    That fitting used to be called a cottage fitting back in the day. Now its just known as a side inlet sanitary tee.
