Thread: Tapping in wall
04-11-2012, 08:10 PM #1
Tapping in wall
Hi,
Need some input.
2 story home built in 2005 while running tub on 2nd floor a tapping can be heard in wall on 1st floor where drain line goes down to slab. No water leaks and only happens with tub running and draining. noise stops after water is shut off and drain is empty.
Mike Richards
Similar Threads:Last edited by Mike Richards; 04-11-2012 at 09:46 PM.
04-11-2012, 08:22 PM #2
Re: Tapping in wall
Expansion and/or contraction of the supply and/or drain piping, which is rubbing against the supports and/or framing as it expands and/or contracts.
Does it do it more with hot water or cold water, or did you only run both?
Usually, it happens more with hot water as the hot water expands the hot supply piping and the drain piping more than cold water does.
04-11-2012, 08:27 PM #3
Re: Tapping in wall
Thanks Jerry,
ran both hot and cold together.
04-11-2012, 09:17 PM #4
Re: Tapping in wall
Since you said there it is leak, I believe there is more to it than what Jerry describes.
