Thread: What is it?
    Default What is it?
    Hot water supply is at lower left, pipe at lower right goes to hot water side of laundry tub faucet.
    Pipe at upper right dives behind drywall and could not be traced.
    (I did NOT pull the pin...)
    Default Re: What is it?
    I'll say a pressure relief valve.
    Connecticut
    Air vent
    water hammer arrestor?
    Utah
    Let me add to the speculation. Two lines in and one out would make me think it is a mixing valve. Not sure about the why, but the installation seems to make sense.
    Garry Blankenship's Avatar
    Garry Blankenship Guest
    Pretty sure that came over on the Mayflower. All you need is the manifest.
    Ding Ding, pass that man a cigar (or a biscuit).
    In IL, still needs air chambers for that laundry faucet even end of run. Appears to be lacking (typical) in the "protection from freezing" department.
