Thread: What is it?
04-18-2012, 12:18 PM #1
What is it?
Hot water supply is at lower left, pipe at lower right goes to hot water side of laundry tub faucet.
Pipe at upper right dives behind drywall and could not be traced.
(I did NOT pull the pin...)
04-18-2012, 12:41 PM #2
Re: What is it?
I'll say a pressure relief valve.
04-19-2012, 07:51 AM #3
Re: What is it?
Air vent
04-19-2012, 09:25 AM #4
Re: What is it?
water hammer arrestor?
04-20-2012, 05:05 PM #5
Re: What is it?
Let me add to the speculation. Two lines in and one out would make me think it is a mixing valve. Not sure about the why, but the installation seems to make sense.
04-20-2012, 05:28 PM #6
Re: What is it?
Pretty sure that came over on the Mayflower. All you need is the manifest.
04-20-2012, 06:31 PM #7
Re: What is it?
