		Thread: AAV or vent
	06-16-2012, 06:14 AM #1 AAV or vent AAV or ventThis trap are is about 8 inches. Is an AAV or vent required prior to the line down sloping.
	06-16-2012, 07:11 AM #2 Re: AAV or vent Re: AAV or vent
	06-18-2012, 01:51 PM #3 Re: AAV or vent Re: AAV or ventMathew, It looks like handyman plumbing 101. I also write up the flexible pipe; One or more sink drains use flexible drain pipe. This type of drain pipe is more likely to clog than smooth wall pipe. Recommend having a qualified plumber replace this pipe with standard plumbing components (smooth wall pipe) to prevent clogged drains. Must be nice up there in PC when it's this hot down here.
	06-18-2012, 03:37 PM #4 Re: AAV or vent Re: AAV or ventThat is called a "S" trap for good reason, and is "illegal". Do you know for sure what is behind the wall? Are you sure there is no tee and vent?
 AAV and a vent aren't really alternatives, the AAV is a different type of vent. If you are sure there is no vent pipe in the wall and the owner/buyer/whoever isn't going to run a pipe vent, I think the AAV is a good alternative. The "S" trap needs to go. There should be no need for a flex pipe with all the room they have under there.
	06-19-2012, 05:43 AM #5 Re: AAV or vent Re: AAV or ventIt looks like if they made the tail pieces longer they could go straight into the wall without the need for the inverted trap at back. I'm not a plumber but I could do better than that.
	07-07-2012, 04:41 AM #6 Re: AAV or vent Re: AAV or ventThey should of came out of the wall with a 45 degree elbow, a short peice a pipe then a trap adaptor. Then they could of used a standard P-trap. The way they did this it makes an S-trap.
 Ron Hasil IL Plumbing Lic #058-160417
 A-Archer Sewer & Plumbing specializing in:
 Tankless Water Heaters | Drain and Sewer Cleaning | Sump and Ejector Pumps | Backflow RPZ Testing
