Thread: AAV vent installed at an angle
08-22-2012, 06:36 PM #1
Must an AAV vent be installed vertically? I know it to be a device that is mechanically operated by negative air pressure within the drain it serves but am not sure. I can't think of a reason it wouldn't operate properly at an angle but it sparked my curiosity. Comments?
Similar Threads:Last edited by Luc V. L.; 08-22-2012 at 06:39 PM. Reason: improper punctuation
08-22-2012, 07:20 PM #2
Re: AAV vent installed at an angle
08-22-2012, 07:41 PM #3
Yeah, that's what Oatey suggested in their online .pdf tech document for their version of the unit but it just didn't jive with my understanding of how they work. Jerry, you're about to hit 20,000 posts!
08-22-2012, 08:37 PM #4
It's not "mechanically operated", it is "atmospherically operated" in that the negative pressure inside the vent lifts the seal, and a neutral pressure allows the seal to remain in place by gravity, and a positive pressure in the vent causes the seal to be sealed tighter.
For the seal to remain in place so that it will seal with neutral or positive pressure the AAV must be close enough to vertical to keep all in proper alignment, and that within 15 degrees of vertical does that.
At 45 degrees, it may not even be sealing properly, or maybe not even sealing at all.
08-22-2012, 08:41 PM #5
Yeah, but who's counting anyway?
I believe I had over 22,000 or so when Brian changed from the old forum to this new forum, but I'm not paying attention or tracking them.
Okay, I will admit that I noticed it when it went over 19,000, and I said to myself 'Well just lookie there at that, I just hit 19,000 again.'
08-22-2012, 08:57 PM #6
What Jerry said with his 3 posts
, the plunger part is binding on the lower side. It will not close properly.
There is no reason to install it wrong except for the reasons of ignorance or indifference.
08-25-2012, 02:07 PM #7
From the photo that appears to be a Mechanical Vent which are not allowed by the IPC. Air Admittance Valves have a different appearance (that of a sealed unit). Mechanical Vents with springs and mechanical movements are prohibited. Reference the IPC Code and Comentary.
