Results 1 to 12 of 12
Thread: Access Panel
10-18-2012, 03:09 AM #1
Access Panel
Typical Texas builder. He says that all he is required to do is install an access panel for the hydro-therapy equipment. It does not matter if you can actually reach the equipment for service or removal . . .
Similar Threads:Texas Inspector
http://www.texasinspector.com
10-18-2012, 04:25 AM #2
Re: Access Panel
Besides the fact that there is no insulation in that part of the exterior wall.
And that it looks like someone went from #14 NM to #12 NM, or vice versa.
Is that a new house or an older house?
10-18-2012, 09:00 AM #3
Re: Access Panel
5 years old. No lintel or shelf angle over the opening in the brick veneer. It was supposedly pre-treated for subterranean termites by a borate application to the framing, but obviously was not, etc. ad infinitum. They also provided a nice big access panel in the skirt of the tub which also did not gain one access to the equipment. 104-page report. Could have been longer.
Texas Inspector
10-18-2012, 09:42 AM #4
Re: Access Panel
For what it's worth (FWIW):
1. various things in the pic suggests a property older than 5 years.
2. perhaps the hydro was an afterthought, and the brickwork for the panel access was simply smashed in, hence the disturbed joints and the lower masonry cracking.
3. thats not re- pointing, of course, merely an amateurish, smearing on.
10-18-2012, 10:24 AM #5
Re: Access Panel
You could show him Section P2720.1 of the IRC, if he can read.
10-18-2012, 10:36 AM #6
Re: Access Panel
Texas Inspector
10-18-2012, 10:37 AM #7
Re: Access Panel
Texas Inspector
10-19-2012, 06:31 PM #8
Re: Access Panel
Bruce Thompson, Lic. #9199
www.TylerHomeInspector.com
10-19-2012, 09:07 PM #9
Re: Access Panel
Isn't it true that you can build a house out there w/o a single permit?
Mazza Inspections and stuff...
https://mazzainspections.com
https://waterintrusionspecialist.com
10-20-2012, 06:28 PM #10
Re: Access Panel
You could show him the manufacturer specs also just for fun.
Don Hester
NCW Home Inspections, LLC
10-25-2012, 09:03 PM #11
10-25-2012, 09:27 PM #12
Re: Access Panel
