Results 1 to 9 of 9
    Sep 2008
    so so, California
    Default Just when I though i'd seen it all...
    Rubber air-hose gas line.
    Default Re: Just when I though i'd seen it all...
    Not acceptable in that specific locations, but isn't that what you use between the propane tank for your gas grill and the burners - a rubber hose? Those ends look like the high pressure ends on those gas hoses.
    I doubt that hose is listed or labeled for use as a gas line, natural or propane.
    Even if it were labeled, it should be located after a shutoff valve.
    On propane gas systems, I sometimes see a rubber hose outside on the bottle.
    But I would call that one - amateur installation, possible leak hazard.
    No sediment trap either.
    There are other things not right in the photo besides just that being a rubber hose in that location, I was just pointing out that being a rubber hose used for gas (if in the proper location) is okay, and gave an example of where one would see a rubber used used day in and day out.
    Sep 2008
    so so, California
    Brian needs to start a link and call it "Best of". Just images of stuff we see daily.
    On the left of the page is a menu
    Click on " PHOTO GALLERY"
    Upload your photo(s) there
    Sep 2008
    so so, California
    Cool, had no idea that was there. thanks once again.
    Jun 2008
    Stacy, MN
    I found a radiator hose, with hose clamps, connecting the gas manifold to the furnace one time.
