Thread: strange addition to vent pipe
12-21-2012, 04:58 AM #1
This is a gas water heater single wall vent pipe, that someone stuck a piece of copper pipe on, for some unknown reason. I could not get the right angle to see down into it, but I stuck a screwdriver down and it appears to not penetrate the vent pipe.
Any theories?
12-21-2012, 05:30 AM #2
Re: strange addition to vent pipe
A spacer to separate the two pipes which has rotated out of position.
12-21-2012, 05:50 AM #3
12-21-2012, 12:44 PM #4
1. The spacer possibility is a good call.
However, given that the vent is single wall type-A - which should have three screws at each connection, how would the pipe roll out of position?
Is that an adjustable length of vent pipe?
2. There appears to be a crack in the metal just below the solder blob.
12-21-2012, 01:44 PM #5
Ha, ha, that's a good one. Three screws at each connection! Ha! Seriously, though, no, not screwed at connections, so could have rotated.
Yep, I didn't know about the crack until I saw the photo. Couldn't see it with my own eyes, I had to reach back there with the camera and kind of point it back at myself.
12-21-2012, 01:56 PM #6
Given the odd and hard to reach position, that might have been a make do handle the installer tacked on to wrestle the pipe into position.
