Results 1 to 11 of 11
    Darrel Hood's Avatar
    Darrel Hood Guest
    Default Gray plastic water distribution pipe - help
    Help, please. This is the first time I have seen this pipe in a home. It is gray plastic and has crimped joints. It is used for the water lines, both hot and cold, in this home. The home was built in 1983. It is a brick home on a slab. Is it poly butylene (sp)? Anything I should know about it before I write this report? Thanks in advance.
    NHIE Practice Exam
    Darrel Hood Guest
    Default Re: Gray plastic water distribution pipe - help
    I will post photos as soon as I can figure out how. I think I am having a size problem . . . with the photos.
    Darrel Hood Guest
    photos of the gray pipe
    Orlando, FL
    That second photo says it all.
    Yes, it's poly. Installed in that manner, and in an attic, indicates a re-pipe.
    Oct 2010
    Southwest US
    Or wait until it leaks, then re-pipe.
    END GLOBAL WHINING
    Mar 2012
    Michigan
    Poly, an interesting failure for plumbing. I found a link that may shed light on it for you. What You Need to Know About Polybutylene Plumbing
    Everything has its beauty but not everyone sees it.
    Darrel Hood Guest
    Thanks folks. Richard, that is a good link for the topic. Thanks to you all, the report is submitted and it almost looks like I know something.
    Mar 2012
    Michigan
    Your welcome. I may be ugly, but at least I'm handy
    Sep 2007
    Fredericksburg, VA
    Every piece of PB I have found in this area is marked PB2110. Distribution pipes are gray and supply pipes can be blue or gray. I have even found one marked with "Big Blue"
    I hate to find blue PVC or Polyethylene main supply pipes in houses built after 1995. They could be PB that a contractor had left over. What idiot manufacturer decided to produce a blue 3/4" supply pipe other than PB in and after 1995? When I see a blue plastic supply pipe in a crawl space, I HAVE to hunt for the markings on the pipe.
    Stu, Fredericksburg VA
    South-West Michigan
    Post Re: Gray plastic water distribution pipe - help
    Polybutene or Quest. Known to leak if not properly installed, and sometimes even when properly installed.
    Randall Aldering GHI BAOM MSM
    Housesmithe Inspection
    www.housesmithe.com
    BLUE PEX is readily available ... as is RED ... WHITE ... clear, dark earthen-ware red, all kinds of colors - while you may use the "blue" color to look for numbers and codes, you probably should look at all plastic piping for that anyway {I seem to recall that they made PB in that familiar gray color, but the PB was also available in blue (to designate cold water) and red (to designate hot water)}.
