    Feb 2010
    Long Beach, CA
    Default Curious Water Heater Vent & Terminal
    I've not seen this gas appliance vent terminal before. The manufacture's web site offers little info. The Cat 1 water heater in the garage uses a 2-foot or so single wall vent connector that transitions to a vertical B-vent run which enters the exposed wood framing flooring overhead where the pipe transitions back to single wall and disappears. The vent pipe is thn routed up a 2nd level chimney chase where it exits the wall as pictured. This seems to be have a single wall collar, no thimble, likely single wall pipe in the wall...anyone seen this before? Of course, all in all--it looks completely wrong.
    NHIE Practice Exam
    Default Re: Curious Water Heater Vent & Terminal
    As you know, single wall should not pass through walls, floors, attics, or roofs.
    Aug 2011
    And you can't neck down from a larger flue to a smaller.
    CAT I appliances must terminate vertically unless power vented by sidewall.
    This appears to be Al29-4C stainless steel special gas vent for CAT III & IV appliance venting. It is single walled uninsulated and not intended for CAT I venting. There is no approved way to attach it to the Bvent since it is not intended for this application. It is all wrong.
    Feb 2010
    Long Beach, CA
    It's crazy wrong...thanks!
