Results 1 to 11 of 11
02-20-2013, 01:33 PM #1
But there is a p-trap under the sink
Similar Threads:Barry Thirtle
02-20-2013, 02:26 PM #2
02-20-2013, 05:08 PM #3
Re: But there is a p-trap under the sink
02-20-2013, 06:37 PM #4
02-20-2013, 06:43 PM #5
Correct ... depends on how the trap is added, and if the trap is "added" to the sink on the left in the first photo *as it is plumbed now*, the sink on the right will be double trapped.
However, if, as shown in your photo, one decides to *re-plumb the drains and traps differently*, then one is not just "adding" a trap to the left sink, one is re-configuring the drain/trap plumbing, in which case (as shown in your photo) each sink would have one trap and only one trap). But all you said was to "add" a trap, not that one would 're-plumb" the drain lines and traps.
02-20-2013, 06:59 PM #6
02-20-2013, 07:17 PM #7
02-20-2013, 07:31 PM #8
02-20-2013, 08:40 PM #9
Thank you for your Interpretation of what you thought you said.
*please Read what was posted.
**nothing was said about re-plumbing and re-configuring the traps, just ( "sink on left needs one. ")
You should consider adding your interpretations of what you THINK you are saying to what you ACTUALLY post.
03-14-2013, 06:54 AM #10
does anyone have a photo of a double trapped sink? I want to show what it looks like to someone but I don't have a photo.
thanks,
b
03-14-2013, 08:33 AM #11
Barry,
Code says:
Double traps (in series) prohibited. IRC 3201.6 UPC 1004.0
Note:No accessible shut-offs visible.
Weird selection of fittings.
The tee appears ( to me ) to be upside down.
Billy,
FWIW: Your pic of G/D etc. is trapped in parallel and good to go.
